little rough
my 95 LT blazer has a very annoying rough idle issue. when stoped, it's very jittery going up and down in RPM's, and it idle's bad. any ideas?
HA...Several.
When was last tune-up? Plugs,Wires, Dist. Cap. Cleaned EGR? Cleaned TBI? |
We've had lots of posts about rough idling. Have you read them to see some of the ideas and solutions?
Vacuum leaks? Dirty/stuck IAC valve on the throttle body?
thanks, only the sparks :\
i have the cap, just havn't did it yet. will be getting wires. and replacing EGR. cleaned tbi? what is tbi, no the smartest here. |
I think he meant TB (throttle body) since you have a CPI motor.
don't mean to sound stupid, but how would i go about cleaning my throttle body?
With some sensor safe carbon cleaner and a brush. The TB is not removable on the CPI motor.
Originally Posted by swartlkk
(Post 215463)
DOH!...yep. |
UPDATE: during yesterday driving, it got worse. when i was stopping and i got around 10mph/lower. if i stopped braking, and braked again they would get stiff as if the car was off and i was just pumping, it got to the point where i couldn't even push my pedal! but it seemed to relieve pressure when i gave it gas. also while accelerated, it seemed as it was going to die, get around 1500RPM's and it's bog for a sec and then speed up.
| All times are GMT -5. The time now is 12:30 AM. |
