location of the egr valve
Old Mar 22, 2012 | 03:20 PM
Kyle Wood's Avatar
Kyle Wood is on a distinguished road
Default location of the egr valve
I'm at it again my blazer was running fine, till my check engine light came on. Sounds crapier and gas is being sucked down. Anyway I was told to try and clean it. Does any one have a picture of where it is or can find one, and what should I use to clean it? My uncle told me brake fluid but I dunno. Any help :]
Old Mar 22, 2012 | 03:29 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
The EGR valve is located on the front of the engine and looks similar to this: http://www.autosparepartsmart.com/im...deville0_b.gif
You'll have to get a new gasket to go with it, try to get one with a scree. I used carp cleaner and a small wire brush when I cleaned mine up
Old Mar 22, 2012 | 05:14 PM
Kyle Wood's Avatar
Is there any way you think I can just clean it and not get the gasket?
Old Mar 22, 2012 | 05:45 PM
Druidic's Avatar
Druidic is on a distinguished road
You could, but that is asking for problems later down the road. I would highly suggest replacing the gasket while you are at it.
Old Mar 22, 2012 | 07:29 PM
50lb_cat's Avatar
Did you have it read for codes?
Old Mar 22, 2012 | 08:42 PM
Chic_Bowdrie's Avatar
Chic_Bowdrie is on a distinguished road
Originally Posted by Kyle Wood
I'm at it again my blazer was running fine, till my check engine light came on. . . . .
Kyle, what was the cel code?
Gents and ladies, is replacement or cleaning of EGR and PVC valves required after so many miles or just when needed?
Old Mar 23, 2012 | 12:32 PM
elfqueen's Avatar
elfqueen is on a distinguished road
Default About the EGR
Hi Kyle,
I'm replacing the spider on my 95 Blazer this weekend, and I plan to clean the EGR valve while I'm at it. I'll try and take a pic of where it is and post it. Everything I have read suggests that getting the gasket with the screen is the way to go. I ordered a Chilton repair manual for my truck from Rock Auto online and it's been very helpful. Lots of pictures and step by step instructions.
Old Apr 12, 2012 | 06:18 PM
elfqueen's Avatar
Default EGR valve location
Sorry it took so long to reply. Here is a pic with the location of the EGR valve. It's the cylinder at the front of the pic. If you replace it, I recommend getting a a new gasket with the screen in it. I was having the same symptoms and I had to replace the entire CPI and nut kit. Mine is running much better, but I still get a bit of rough idle at times.
Old Mar 11, 2013 | 07:45 PM
joshn444's Avatar
joshn444 is on a distinguished road
Does anyone know how much it is to take it to a mechanic and have them just replace it?
Old Dec 22, 2023 | 02:40 PM
Blazer03chevy's Avatar
Blazer03chevy is on a distinguished road
Default Can't find it.
can't find it
I looked at the front and it's not there. When I look up where its at everyone esle has it there but I dont... I'm just confused.. my truck has a rough start. Then when I put it in gear it dies. I replaced the fuel pump, fuel filter, rebuilt transmission, new starter, new battery.... I'm out of options so now I'm trying the egr vaulve but I CANT FIND IT!
