Low oil pressure 20psi at idle
i just changed my oil last week and my oil pressure is staying at 20 on idle and it goes to 40-41 psi at 2000 rpm. what can i do to get the psi right
it is a mix of 5w-30 and 10w30. 2/5 and a stp filter.
And what is it at cold start, 1000 rpm?
the oil pressure stays the the same at 20 cold or hot. 168000 miles
had her since august of 2011 and the LIM gasket seams fine to me. the dealership did the motipoint inspection and he found evidence a oil leak but my oil levels do not drop. many be a past leak?\ and the pressure was the same before the change. cold rpm is at 1000-1200
I agree. If the mechanical gauge says the same then you can go from there
lost113
Dec 11, 2011 06:08 AM
