lucas oil problem
so i used lucas oil heavy duty additive today with my oil change, now my truck is starting very rough, could it be i used too much oil or is the additive no good, i don't want to wreck anything, it is running good however after start, i did my best to add 1qt or lucas and 3.5 of oil
I don't think an additive in the oil would have any effect on how the engine runs. Maybe you pulled a vacuum hose off while you were under the hood, or something similar? Double check that it's not overfilled while you're there, although I'm not sure that would cause a hard start.
ComputerNerdBD
Feb 9, 2010 05:05 PM
cide
Nov 7, 2009 01:26 PM
ComputerNerdBD
Oct 17, 2009 04:46 PM
