Major Transmission Problem
Old Nov 20, 2014 | 01:05 PM
bbthekid's Avatar
bbthekid is on a distinguished road
Lightbulb Major Transmission Problem
So I have an 85 k5 blazer with a 700r4 tranny. My transmission won't engage in reverse and when its in neutral it drives forward when i let off the brake. All the other gears work as well. I put it in reverse and apply the gas and it will rev up to low rpm and same for when it' s in park. I checked the linkage and it was fine and engages in all slots.
Before this issue when i was driving it would rev really high in between 1st and 2nd gear and even in other gears and would have trouble shifting. and when i would try to go in reverse it would either rev up really high rpm and take a while to slowly inch backwards or just inch back and than pick up speed and when i would stop after it gets up to speed in reverse i could go back at normal speed.
I've also had a transmission leak in the cooling line for a long time before this issue and still have it but where the leak is it solidified to a pick gum texture but still leaks regular looking fluid.
Can someone please give me some feed back on what is wrong and what I should do.
Spectreblazer
Feb 2, 2010 07:42 PM
Chevy Blazer
49
Jan 5, 2010 06:39 PM
S10Blazer
Dec 6, 2009 01:58 PM
ComputerNerdBD
Jun 30, 2009 11:59 AM
firefighter9556
Nov 29, 2007 11:01 PM
