MFI Conversion
Here's the thread that has the part numbers: Hard Starting - Fuel Pressure Concepts
Please note that all you need is the spider assembly. The new assembly fits in the old bracket. The rest of the o-ring seals for the upper plenum, etc are available separately from many sources, but are not really necessary so long as you clean and inspect your original seals. The new MFI comes with new fuel link o-rings, but you may want to get new o-rings for the fuel lines at the back of the engine, I know I cut one and needed to replace it.
shanegreen
Apr 30, 2012 02:38 PM
catmech
Oct 17, 2010 08:50 PM
Patrick_Boyle
Aug 22, 2009 05:28 PM
