mifire cyl 6 EVAP PO449
Old Jun 18, 2018 | 08:49 PM
maddog3357's Avatar
maddog3357 is on a distinguished road
Default mifire cyl 6 EVAP PO449
I am having a misfire cylinder 6 issue also EVAP PO449 error. Replaced rotor, dist. cap, plugs and wires, all ACDELCO.
Replaced gas cap and vacumm hoses. Genuine ACDELCO cap.4.3l TBI 2001.
Old Jun 19, 2018 | 07:13 AM
LesMyer's Avatar
Can you feel a misfire, or is it only a SES light?
Old Jun 20, 2018 | 02:48 PM
maddog3357's Avatar
Doesn't feel like a misfire. Spark plug gets spark. Error comes up on hand held computer, also when operating temperature idles 500 rpm lower.
Old Jun 21, 2018 | 07:43 AM
LesMyer's Avatar
Mine idles at 550 in drive when warm.
If the "misfire" isn't felt and is not turning on the SES light, then it is not considered to be a problem. Pending codes showing on a scanner or some misfire counts in live data do not necessarily meet the criteria established as a real problem.
P0449 is the PCM recognizing an electrical control problem with the evap vent valve above the spare tire. As I understand it, it is fairly common for the wiring to the valve to get damaged on the driveshaft. Otherwise, use a scanner capable of cycling the valve, get a wiring diagram, and diagnose accordingly. Car Gauge Pro/BAFX OBD2 adapter will cycle this valve for certain as I have done it on my 2001 Blazer and 2004 Avalanche. Good luck.
P.S. 2001 is not TBI
Rleandro
Mar 8, 2018 04:50 PM
Slim6969
Dec 9, 2016 08:18 AM
jcorbeil
Jul 16, 2011 09:22 AM
phatskier20
Jul 25, 2008 01:46 PM
LittleT
Oct 23, 2007 01:02 PM
