Misfire
I have a 2000 blazer 2wd manual trans. It recently developed a misfire. It shows the random misfire code and p0452 and p0453. I have changed cap, rotor, plugs, wires, fuel filter, coolant temp sensor, spider injection. Does anyone have any ideas on what my problem could be? Thanks a lot for the help
I also own a 1999 blazer and mine also has a ugly miss fire!!! only on cyl2 and 4. do the 4.3l engine tend to burn valves???? im from south Africa and the few people that says they know these motors say the motors is bullet proof!!!
I tried to check fuel pressure and got nothing. I figured it was a bad gauge I rented. This car is actually a friend's that I am trying to work on. I think it has around 130000. How bad would a burnt valve make it run? I don't think this is that severe of a misfire. Wouldn't that run pretty rough?
hi I found my missing cause!!!! my motor broke a valve spring!!!!!!! so its costing me engineering skim head re-lap valve and source a valve spring!!!! hopefully the v8's valve spring fits!!!! then I must source a head gasket set also!!!! I only removed the faulty head, to much work to take the other head off. I actually took the tappet cover off for 3 -4 times and didn't se the broken valve spring!!! hope I could help!!!
rrk03300
11-15-2012 10:29 PM
wythel
27
01-30-2006 02:04 AM
wolfe1967
08-29-2005 12:27 AM
