misfire p0300 97 blazer
Old May 21, 2015 | 08:48 PM
bean2013's Avatar
bean2013 is on a distinguished road
Default misfire p0300 97 blazer
I was driving down the road other night and the truck threw code p0300 I change the Ing coil plugs and wires was change last month pulled the plugs they still look good it has a rough idle in park then stick it in drive it either cuts off or runs really bad any ideas what could be causing this
Old May 22, 2015 | 01:22 AM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Captain Hook posted a link how to test and diagnose the fuel system ......as far as secondary ignition u need to use only ACDELCO ignition parts.........plugs,cap,rotor , wires however u can get away with auto lite professional wires , however that is the only thing u can skimp on.....if u use aftermarket cap,rotor,plugs u will surely have issues!!!! Goodluck
Old May 22, 2015 | 07:45 AM
bean2013's Avatar
I will give it a shot see what I can up with
Old May 25, 2015 | 08:04 PM
bean2013's Avatar
The fuel filter was clogged change that and still doing the same anymore ideas could cause this problem
b_didddy510
Mar 29, 2019 06:57 AM
sputtle
Apr 20, 2014 04:46 PM
vaportrail
38
Sep 21, 2009 05:38 PM
vaportrail
Aug 16, 2009 06:15 PM
Sk8Jitsu
Aug 16, 2009 02:16 PM
