Missing at crusing speed
Old Feb 25, 2009 | 09:07 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
Default Missing at crusing speed
I know this has been brought up before but this was not answered. I have been having a small issue of my blazer missing, bucking , a little at 70 MPH (2k RPM). It only does it for a bit and sorts out after a couple time. I did a seafoam treatment and it helped a lot. It started again the last couple of days. Yesterday I put 93 octane gas in it and noticed this morning that it ran great. Very smooth and not missing or bucking. Could it be that I still have build up on the combustion side of my engine? This engine only has about 60-70 K on it and was crazy clean on the inside. I may do another seafoam treatment and see if that helps. I have not pulled codes. I could stop by AutoZone and do that too.
Old Feb 25, 2009 | 12:05 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Default RE: Missing at crusing speed
It could be moisture built up inside your distributor cap that evaporates once it's warm. Do you ever have trouble starting it after a cold, but humid night?
Old Feb 25, 2009 | 02:59 PM
samuknow's Avatar
It starts on first bump. Especially after the seafoam in the tank. I will see if it does it on the way home today. It is about 50 today after being below 30 for the last few days.
Old Feb 25, 2009 | 03:23 PM
bandidolenny's Avatar
Try replacing your cap, rotor and fuel filter...then do a fuel pressure test just to make sure that your pump isnt taking an early vacation.
Mgern26
May 19, 2012 03:23 PM
wisowebs
Dec 31, 2011 05:33 PM
ffox
25
Mar 18, 2011 12:12 AM
BubbaBrooks
Jan 17, 2011 07:37 PM
jdpilot
Nov 12, 2008 06:01 PM
