MPG's
Old Jan 29, 2008 | 08:08 PM
  #21
drperry's Avatar
Default RE: Try the shell gas
ORIGINAL: BlazerSS
thanks for voulanteering Zasder! I would do it as well, Im just a little low on fundage right now. Make sure you read the directions, as I believe when you add it to your tank of gas, you are supposed to initially add 3-5o.z. to your oil as well one time only. Keep us updated.
I doubt you need to add it to your oil...
I'd reccomend against adding foreign substances to your engine oil unless it's needed
Old Jan 30, 2008 | 11:09 AM
  #22
Zasder's Avatar
Zasder is an unknown quantity at this point
No you add 3oz first time to your gas tank
Then for every fill up you use 2oz (since I have a 19 gallon tank) it takes 1oz for every 10 gallons
this stuff isnt going anywhere near my oil lol
Old Jan 31, 2008 | 08:21 AM
  #23
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
I suggest youread the entire article about the product, it specifically statesthat you need to "add 1o.z. ofEthos per 1 quart of oil to youroil to see maximum results".
http://www.thegassecret.com/
Old Jan 31, 2008 | 11:21 AM
  #24
Zasder's Avatar
Ok, maybe I will then
I found a 32oz bottle for 30 bucks, so here we go!
Old Jan 31, 2008 | 12:06 PM
  #25
lennyblazer's Avatar
lennyblazer is on a distinguished road
ORIGINAL: Zasder
Where'd you find that, all I saw on their website was 32oz for 53.95+shipping. As for adding it to the oil, I am not sure why you would need to do that, as I don't like adding anything but oil to my oil system. Well let us know what you find out. Also they said it could take up to 3 tanks to start seeing the full benifits. Sounds like it would be great for my trips on state highways where the speed limit is 55, since I do between the speedlimit and 60mph and can normally get around 23-25mpg doing that, with that ethos stuff I might be able to pull off 24-28mpg. It would be interesting if they showed results from say a truck/SUV with a V6 or V8.
Old Jan 31, 2008 | 01:34 PM
  #26
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
I filled up my truck with BJ's gas and no problems. Truck was on empty and I had to get gas so I was driving past itand went there
Old Jan 31, 2008 | 08:10 PM
  #27
Zasder's Avatar
I found IT on EBAY... lol
Old Feb 1, 2008 | 02:07 PM
  #28
Nice, glad you could find IT on ebay.
Old Aug 9, 2009 | 06:07 AM
  #29
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Default tranny/differential flush
Originally Posted by Mr Blazer LT
When's the last time you did a tranny/differential flush? Last time I did mine, my MPG skyrocketed up. Do you have 4WD?
How do you do that flush?
Old Aug 9, 2009 | 10:29 AM
  #30
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
Default Mpg
a friend of mine had a 2000 blazer and had a bad sensor goin to his fuel injector. this was in the summer and he was getting 11-14mpg. Gasoline quality does make a big difference just like everyone else was saying
