multiple random missfire
Old Feb 27, 2015 | 07:48 PM
jcc0510's Avatar
jcc0510 is on a distinguished road
Default multiple random missfire
Ok new to the forum and I know this has been mentioned a number of times and I did look through the forums and found nothing. The issue is a po300 code that started last week driving to work. Long story short fuel pressure is good and holds, compression is good and holds. So far parts that have been replaced consist of spider injector, fpr, wires, plugs, cap and rotor, and distributor but yet problem still exists. What baffles me is when I pull wires from the distributor (5,1,3) no change in idle as well as fuel dumping out the exaust. When in the vehicle you can definitely feel the missfires. Can somebody please point me in the right direction.
Old Feb 27, 2015 | 08:28 PM
jcc0510's Avatar
Forgot to mention it's a 2000 jimmy 4x4
Old Feb 27, 2015 | 09:18 PM
fj4072's Avatar
fj4072 is on a distinguished road
Have you tried AC Delco brand cap and rotor? I have found that aftermarkets aren't designed correctly and short. Chased P0300 for a while until someone told me about the aftermarket problem caps.
Old Feb 27, 2015 | 11:07 PM
jcc0510's Avatar
Yes ACDelco everything it's the only part I'll put in it. I even tried swapping the coil and nothing.
Old Feb 28, 2015 | 08:27 AM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default try this
I would inspect\clean the MAF and make sure the TBI cover gasket is still good and make sure the air induction system is secure with no leaks..
Old Mar 2, 2015 | 05:38 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Double check the seal where the spider comes through the upper plenum. these are known to leak vacuum if they do not seat correctly. i had to use a lubricant on my new seal when I replaced mine to get it to go down all the way.
professax
May 3, 2014 02:31 AM
KidBlazer
Feb 7, 2013 11:08 AM
tim68
Jul 18, 2011 06:50 AM
darias
Apr 12, 2007 03:49 PM
SlimshagE
Apr 9, 2007 10:00 PM
