my 01 blazer smoking black...
okay soo bank 2 senso 1r was has been going out i have replaced it three times and it will function properly for two three days then will stop responding and of coarse throw the low signal voltage code. and yet again it will role coal. soo i am at a loss i already did continuity test between the heater and the computer and also have check the signal wire to see if there is an ohm issue and there is not, i know that o2 sensors create there own voltage soo there isnt a supply hot for the sensor soo what i have collected is there is some sort of contamination getting in it but my coolant is full and has been full for the last three weeks. my fuel trim are running somewhere around 40-50% positive. idk has anyone else had this problem? if so help me out i have ran outtta ideas (and no it is not throwing a lean code)
when i first replace the o2 sensor it doesn't smoke that i notice, like it is possible that i am burning oil and its causing it to malfunction but if it is burnin oil its not bad enough to foul an o2 sensor i havent noticed a drop at all in my oil level since i changes it 1200 miles ago. oh and the 40-50% fuel trims are just on the right bank the left bank run in the norm -2 to 0% fuel trim. and it is raw fuel coming out not oil, like legit my blazer smokes more than my buddies 7.3l
if its smoking that bad, I would suspect something other than valve seals. I have bad valve seals on my jimmy, and it only smokes for like a second at start up.
Have you smelled the exhaust (yeah, not the advice you would get every day) but what does it smell like?
Black smoke usually is an indication of excess fuel. First thing I would do is smell your oil, see if it smells like raw fuel. and then do a fuel pressure test.
Yeah, that's why I mentioned piston rings, but he says it isn't burning that much oil. I don't now much about fuel trim on these vehicles, but I'm guessing yours is high? If so, it may be fouling the O2, but it's kinda doubtful. How about injectors? Are they all running ok?
For the right bank to be so far off does seem weird. I would even hazard to guess the computer might be going bad, screwing up fuel trim and therefore the O2 sensors. But that's a long shot.
Theres a new similair thread
The thread has pics and all I suspect you have leaking full regulator and bad injectors.Remove your top planem off and look for cleaned washed areas and puddles of gas.My guess if you fix this your problems will be solved.Seems to be a very common issue.
FemmeVamp
08-29-2007 12:13 PM
