My ecm wires burned up
Old Feb 28, 2022 | 04:11 PM
Jo_Boy's Avatar
Jo_Boy is on a distinguished road
Default My ecm wires burned up
I need help my ecm wires burned up I think it’s from the exhaust tube the 90 fitting rotted thru and most of my wires burned out and I need to confirm if anyone had this problem
The vacuum hose from the solenoid also burned thru
Old Feb 28, 2022 | 07:41 PM
Mods's Avatar
OH DAMN
in my build thread i posted a long holy-hell-replace-your-valves rant when that happened to me while flying down back roads lol.
i had my machinist make blockoff plates, install new studs and nuts when you do replace them. removing that system will not do anything unless you are in california or a state with emissions inspections yearly. check with local laws.
I can pull the PCM Diagram possibly, give me a little bit to find it.
Old Mar 12, 2022 | 04:24 PM
Mods's Avatar
i cant seem to find the copy i had on hand, so best bet would be to de-loom the harness, and match your wires, chances are they are still connected just melty so physically trace each one back to where it goes and match color/stripes along the way, and seriously consider doing an A.I.R Delete.
pjdupont1
Mar 6, 2022 11:13 PM
HARDTRAILZ
Apr 14, 2011 12:25 AM
Baja Blazer 85
Sep 14, 2009 04:20 PM
Logan
Jul 19, 2009 10:20 PM
BLK85
Jun 7, 2007 10:49 PM
