Mystery Leak?
Old Aug 15, 2016 | 01:49 PM
nickhex1989's Avatar
nickhex1989 is on a distinguished road
Default Mystery Leak?
Just got a 95 4x4, 4.3L. Blazer. First off I will mention that I need to replace the brake booster and master cylinder. But the issue is: been seeing small puddles in the morning after the truck sits overnight. But, none of the fluids seem to be going down at all, yet the fluid has a light brown tinge to it. Not sure if water picking up the rust from underneath or is a leak. By the front driver's side and in the middle seem to be where wet spots are. Any thoughts?
Old Aug 16, 2016 | 02:00 PM
Think I found the leaks...very small trans leak and a power steering leak. Put stop leak in and puddles decreased a huge amount. Also going to do a trans oil and filter change.
Old Aug 29, 2016 | 05:35 AM
greatwhitenorth's Avatar
greatwhitenorth is on a distinguished road
Just my two cents but I wouldn't rely on them stop leak jobbies. Just a bandaid that'll fail you when you really need it in my experience.
btbs89
Aug 3, 2011 08:50 PM
DATEGGY39
Feb 5, 2011 11:28 AM
andrew919
Mar 11, 2010 08:35 PM
ironclad
Aug 18, 2008 04:05 PM
lizardqing
Aug 17, 2007 09:55 PM
