Need help!
Old Apr 15, 2013 | 11:48 AM
Robert MacGilfrey's Avatar
Robert MacGilfrey is on a distinguished road
Default Need help!
I have a 2003 Blazer 4wd 2 door with 4.3L. Over the las 2 years I experienced sputtering and stalling issues. After stall out it would just crank with no fire. Had to let it sit for a long time then it would fire right up. It used to be only when it was hot out and then when fuel was below 1/4 tank. It just recently left me on side of road. I went thru and gave it a complete tune up. New coil, distributor assembly, wires, plugs, IAC, MAP, Purge Valve, PCV, IAC and ECT. Ran better but would stall after 3 mins idling. Got evap codes P0443, P0449. Replaced fuel pump also after hearing it bog down right before stall out. Truck runs great now. But now does not want to stop. When I come to stop it looses idle and stalls. Starts right up. Only codes are EVAP P0443 and P0449. Any Ideas for Idle issues and stalling?
Old Apr 15, 2013 | 02:43 PM
El_Beautor's Avatar
Do you have a vacuum leak somewhere? Also check the hard 3/4" tube that goes from the back/top of the air intake to the passenger side cylindar head. If that got left disconnected it can cause the truck to bog down and maybe stall when stopping.
Old Apr 15, 2013 | 04:26 PM
I will check the vacum leak. Thanks.
1hugeblazer
Feb 21, 2011 06:05 PM
maximashift
Nov 17, 2009 09:36 AM
maximashift
Nov 17, 2009 09:33 AM
blazin4eva
Jan 27, 2005 02:02 PM
