need help. cant get to start and back firing though intake
Old Sep 21, 2011 | 01:49 AM
tylerbrewer's Avatar
tylerbrewer is on a distinguished road
Cool need help. cant get to start and back firing though intake
i have a 2000 s10 blazer wit a motor out a 96 in it. It started making this weird thumping sound out of the exuast not like a back fire its a thump and when i was try to start it, it was doing some kind of back firing thing from the intake where it sucks air in i put a new fuel pump on it and a new rotor button i dont no what else to try?
Old Sep 21, 2011 | 01:57 AM
chris015's Avatar
Check the timing?
Old Sep 23, 2011 | 01:00 AM
FsTFwRd's Avatar
Cat converter, fuel pressure regulator, fuel filter, Injectors, bad gas? These could also be your problem.
Old Sep 23, 2011 | 09:27 AM
pettyfog's Avatar
I assume it ran good at some time then started acting up. Why did you change fuel pump? Was it for this problem?
Changed rotor but not cap? If the rotor was trash, the cap usually is as well. That can lead to crossfire with those symptoms.. as can installng plug wires wrong.
What happened at the time just before this started? It sounds like either timing or a more basic engine problem.
Seriously, at this level, I dont think you're going to be able to solve it without up close and personal help.
Old Oct 12, 2011 | 08:18 PM
RIFLEMAN 308's Avatar
RIFLEMAN 308 is on a distinguished road
check the crank position sensor and the connector going to it, i mean the terminals inside the connector that is, the tend to spread apart slightly over time causing the socket to fail to make contact with the pin on the sensor, believe me i had the same exact thing happen to me, 3 hours of testing wiring all the way up to the controller and beyond ( IN THE RAIN!!! YEAAA!!!)
97olered
Jun 24, 2013 01:00 AM
cdw78
22
Jul 23, 2011 07:56 AM
mattnew4
Dec 19, 2010 05:47 PM
lilgene21
Aug 18, 2010 02:50 PM
olenmarmcr
Oct 6, 2007 11:10 PM
