need help coolant leak!!!!please overheating
my 96 blazer i guess was low on antifreeze and after i raced sum1 today i pulle up and it was mildly smoking...i relized there was no anti freeze in it so im almost 2 the store and it strats overheating to where it says check gauges.......i put in antifreeze in the add reservoir and put the rest in the radiator.....still overheated then when i looked on the side of my truck i seen the antifreeze in the snow.......i bought 2 gallons of water and put them in the radiator and as soon as i do that i look under it and its coming out fast but not from the radiator.....it drips down off the oil pan..like where the oil drain plug is..........please tell me its just a belt or something minor!!!!!!any help would be nice.........christmas and this happens
if they are what is it going to mean? it drips down from above and drips off by the oil drain plug....but i think it may be like running to their because it leaks a little bit a little closer to the front..
ok first off ... check ALL hoses , THEN check around front of engine by the water pump, and if you STILL havent found the leak then look around below spark plugs and on dipstick for goldish milky oil if you find it on dipstick you either cracked the headgasket or head Or worst case the Block~!
dont forget the HEATER hoses for heater core can cause the leak too .. alot of ppl forget they hold fluid lol
mytruck starts up fine......my heater has been giving me alot of problems lately! like i gotta punch the compressor for it to work......i listened for the leak and it sounded like it was bubling out of a hose....does a water pump make that noise? il def check the coolant tomorrow....if no coolant in oil should i be ok? if it was that would it still start
ORIGINAL: felonyblazer96
any other advice?
any other advice?
What have you done to try to rectify the situation?
um nothing because im 50 miles away at a party........cnt do nothing till tomorrow and i wanna see all possibilities.....if you aint got advice dont talk to me
i wouldnt even leave it i sat in it 4 for hours until i got ahold of my uncle to tow me
