NEED HELP--- Knocking noise can't diagnose
Old 03-07-2010, 11:42 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
If it is a rod Knock it will be more that just replacing the Bearings. Crankshaft will more than likely need to be replaced also. Medal shaving through out the engine from the bearings being bad. That is why I asked about the oil pressure. I would Say Better be looking for a engine. Man that sucks,,, Sorry to hear this I know. Good Luck
Old 03-08-2010, 10:59 PM
adaptechsolution's Avatar
adaptechsolution is on a distinguished road
just thought of something... is there a way to flush the whole engine out to make sure that you remove and debris that may be left by an old bearing... I'm sure there has to be a way. on top of that though, if it were a connecting rod bearing then i should see at least some small granulation of debris when i drain the oil right?? again thanks everyone all the suggestions are great an appreciate it.
ntjoe
10-08-2010 04:54 PM
Renthorin
10-02-2010 05:47 AM
shaggy_5420
08-04-2010 11:27 PM
cathys0715
05-17-2009 05:33 PM
Reyd_01
03-01-2009 07:08 PM
Quick Reply: NEED HELP--- Knocking noise can't diagnose
