Need Help With my trucks hiccup/hesitation!
Old Sep 30, 2013 | 02:20 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Default Need Help With my trucks hiccup/hesitation!
Alright. I need help figuring out what the hiccup on my truck is. I've done a lot of workto rthe truck so I'll try to name it all. Its a 2000 4.3 with a Cam, Cold air intake, Short tube headers to a custom magna flow exhaust, Egr delete and block off plate, Throttle body mod, and a Wait 4 Me tune. The problem is off idleonly iI have a hiccup/hesitation where the truck starts to go, Bogs down or hesitates then continues to go on its way perfectly past that point. Now ti did some digging around the truck and I found out if you unplug the maf sensor the hesitation goes away and the truck drives as if I wish it would. So I had replaced the maf sensor and still not an ounce different and the problem consists still. I also took some carb Cleaner and sprayed around the intake and throttle body to see if there's a vacuum leak after the maf sensor causing off a/f ratios but I couldn't find anything or get the idle to spike up from the carb cleaner. Anyone have any help or tips on what to try and do? Thank you in advance for your help!
Old Sep 30, 2013 | 05:00 PM
chris015's Avatar
remove the egr delete,and test it.
Old Sep 30, 2013 | 11:14 PM
PaulO2288's Avatar
Well I also deleted it because when getting my computer tuned I had got another PCM from my old truck which never had an egr. So that one had been tuned to run with it ever so I had made a block off plate for it
Old Oct 1, 2013 | 07:51 PM
PaulO2288's Avatar
Anyone?
Old Oct 18, 2013 | 01:46 PM
cheapazz's Avatar
cheapazz is on a distinguished road
My full size does that if the timing is too advanced........maybe? Just a thought.....
Old Oct 24, 2013 | 08:13 PM
charliebrown's Avatar
charliebrown is on a distinguished road
HI,I have somewhat of the same problem.
I can not find the called EST WIRE to disable timing to set timing to mark on crank shaft it is supposed to be a single wire under dash,but the closets
that i got were a small wire bundle by computer bundle,thanks
97cherryblazer
Jun 15, 2011 06:37 PM
garynye30
Aug 26, 2010 02:21 AM
CountryRed
May 5, 2010 04:39 PM
corvette535
Mar 10, 2009 05:46 PM
rusignuolo
Feb 19, 2009 06:49 AM
