-   -   Need help with throttle cable, upper intake... (https://blazerforum.com/forum/engine-transmission-35/need-help-throttle-cable-upper-intake-74753/)
E_James Oct 24, 2012 04:27 PM
Hey guys, so I am removing my upper intake to replace my fuel spider. I have so far removed the air intake, disconnected the fuel lines from the firewall area, and removed the nuts holding the throttle bracket in place. So, now, the throttle bracket is free but just dangling in place. There is 2 cables ( i guess one is the throttle and one is cruise control? ) So, how do I disconnect the cables so I can remove the upper intake to access the spider. Any help would be appreciated. I am trying to upload pics now of my progress thus far....
richphotos Oct 24, 2012 06:23 PM
you pull back on the throttle linkage and they are just held in place with a post at the end, kinda like the brake cable on a bicycle. When you relieve the tension, you will be able to turn and remove.
E_James Oct 24, 2012 07:00 PM
Cool, I will give it a shot tomorrow. I just did not want to break the cables, seems like it would be a tough fix.
drew.shaneyfelt Dec 29, 2012 03:04 PM
need help removing throttle cable
2 Attachment(s)
Hello,
I've been working on the same repair and ran into the same problem. I've got the cruise control cable off, but the throttle cable will not budge. the throttle cable connector seems to go completely around the mounting peg with no way to slide off. I have attached an image. any ideas?
thanks,
-Drew
swartlkk Dec 29, 2012 03:11 PM
Originally Posted by drew.shaneyfelt (Post 558788)
Hello,
thanks,
-Drew
What you have removed already is the main throttle cable and what you have left is the cruise cable. The cruise cable is held on by a plastic c-clip that is visible in the picture you attached. The clip must be removed to detach the cable end from the throttle linkage. A small flat blade screwdriver or a sharp awl should be used to pry the c-clip out along the long portion of the body of the cable end. Careful as the clip likes to go flying and often will find it's way into a dark nook in the engine compartment never to be seen again.
drew.shaneyfelt Dec 29, 2012 03:55 PM
much thanks!!!
As soon as you said it was a c-clip it was very apparent how to take it apart. and also, just like you said, it found its way into some dark nook or somewhere on the garage floor. we shall see. thanks again. This small part was becoming a huge hurdle to the larger repair. now back to the garage.
Drew
abig84 Dec 31, 2012 10:23 AM
another easy method is if you dont want to mess with that clip or paranoid about breaking it just remove the throttle body. its 3 bolts then you can just place the cables with the throttle body on it to the side, last time i tried to get one of those off it just wouldnt budge
m0perale Dec 31, 2012 02:32 PM
I did bust my cruise cable retainer, unfortunately. 13 years old, desert heat (and before that Michigan winters) caused it to be brittle. I found retainers online, but they all claim to fit 2000+ vehicles (mine is 1999). Does anyone know if the replacement listed here will, indeed, fit my blazer? If not, is there another part I haven't found yet? I'd prefer not to replace the whole cable. Thanks.
m0perale Jan 1, 2013 03:53 PM
Bump. Thanks.
swartlkk Jan 1, 2013 04:29 PM
The cruise control cable does show as being a different part number between the 97-99 & 2000+ years, but Tonkin's website doesn't give any indication as to the differences. Could only be in length or attachment at the cruise control module itself as I do not recall noticing any changes at the throttle body side of the cable. I also do not know if I have ever really paid any attention to that area in the past.
Does that part look like what you have? If so, take a chance then let us know.
