need help with tranny
I have a tranny problem. I have a 95 blazer 4l60e tranny that i had to rebuild due to no reverse. i drove it like that for a year until i hauled a load of bricks. After that it would not shift out of first gear. So i took it out and rebuilt it. Got it done put it back in and now it won't shift out of first still. I cleaned the valve body and pump. Had to use the old torque converter due to money but there was no metal shavings anywhere in the tranny. i haven't got any godes yet. Can anyone help. If you need any more info just let me know
There are so many things that you can do wrong in the rebuild process...
The fact that you did not cure the problem with the parts you replaced in your rebuild helps.
Checks - Causes:
Control Valve Body -
Checks - Causes:
- The 1-2 Shift valve is sticking
- The spacer plate or gaskets are mispositioned or damaged
- The case to valve body face is damaged or is not flat
- Stuck or damaged
- Faulty electrical connection
- The apply passage case is restricted or blocked
- Nicks or burrs on the servo pin or on the pin bore in the case
- Fourth servo piston is installed backwards
- The 2-4 band is worn or damaged
- The band anchor pin is not engaged
ski.dive
Feb 7, 2014 05:18 AM
Russyo
Jan 10, 2007 01:11 PM
