Need help, unusual knocking problem.
Old Apr 15, 2012 | 01:38 PM
Bubbatank's Avatar
Bubbatank is on a distinguished road
Default Need help, unusual knocking problem.
So I'm driving home and my temperature gauge starts reading hot, like almost all the way on the red, then it goes all the way right (overheating) and I slow down, as I come to a stop the temp gauge swings all the way back cold and I start to hear a tapping (knocking)
I Turn the car off and open the valve on the radiator cap, I then go to fill it up with water and its already full??? So I start the car, same thing, knocking and I get the car towed home because I dont want to continue to break whatever is broken.
I turned the car on this morning and still the knocking, Any ideas on what it is, or what I will need to do to fix it, or am I already screwed.
Thanks
Old Apr 15, 2012 | 02:34 PM
chris015's Avatar
if its an actual engine knock,you are going to enjoy installing a new engine.
Old Apr 15, 2012 | 05:35 PM
50lb_cat's Avatar
Doesn't sound good, what level is your oil at?
Old Apr 15, 2012 | 07:16 PM
Bubbatank's Avatar
when i checked the oil, it looked fine, i added a quart just to see if the tapping (knocking) would go away, but it didnt
Old Apr 15, 2012 | 10:26 PM
chris015's Avatar
get us a video. Might be lucky and it be a loose torque convertor bolts.
Old Apr 15, 2012 | 10:38 PM
4x4blazerguy's Avatar
Is it a tapping or a soft or hard knock. Is it all the time or just certain RPMs? Was the engine HOT when the temp gauge went HOT. It sounds like it wasn't boiling. My first thought was a countershaft knock. I guess because I drove my 97 Blazer almost 100,000 miles with a countershaft knock.
TiaRC
Aug 31, 2014 07:18 PM
racsan
Feb 24, 2012 09:30 PM
03blazerG
Dec 21, 2009 08:57 PM
hastys
Dec 18, 2007 03:08 PM
garry2000blazer
Aug 7, 2007 12:27 PM
