need a second opinion
I'm no domestic guru by any means, I mostly work on my drift car but my Jimmy is broken with the classic water in my oil. I started pulling it apart the other day to diagnose whether its head or intake gaskets that failed.
After pulling off the pulley bracket on the drivers side bank (cyl.1,3,6) i noticed some chocolate milky sweetness leaking out between the lower manifold and the head. I compression tested all cylinders and they ranged between 120psi-130psi.
Should i be good and just do the intake manifold gasket? Or could it possibly still be head or both?
Any insight is much appreciated. Thanks
