need a second opinion
Old Sep 29, 2009 | 03:29 PM
berryd8's Avatar
berryd8 is on a distinguished road
Default need a second opinion
I'm no domestic guru by any means, I mostly work on my drift car but my Jimmy is broken with the classic water in my oil. I started pulling it apart the other day to diagnose whether its head or intake gaskets that failed.
After pulling off the pulley bracket on the drivers side bank (cyl.1,3,6) i noticed some chocolate milky sweetness leaking out between the lower manifold and the head. I compression tested all cylinders and they ranged between 120psi-130psi.
Should i be good and just do the intake manifold gasket? Or could it possibly still be head or both?
Any insight is much appreciated. Thanks
Old Sep 29, 2009 | 05:06 PM
Definitely sounds like a failed LIM gasket.
Get the redesigned ones from Felpro that have an aluminum frame.
Old Sep 29, 2009 | 06:28 PM
berryd8's Avatar
Yea that's what i figured, but i just wanted to make sure. I'm not too sure about the compression being ok considering i don't even know the compression ratio. I'll order a Felpro and call it a day
97Bravada
Jan 20, 2010 07:38 PM
gscrippler
Dec 17, 2008 08:02 PM
trinaxt
Jan 29, 2008 01:10 PM
Chevy Lover
Mar 6, 2007 11:56 PM
knightrider79
Sep 6, 2006 12:35 AM
