Need some help
Old 01-15-2019, 02:48 PM
Scott W Bucher's Avatar
Scott W Bucher is on a distinguished road
Default Need some help
Hey everybody. I have a 79 k5 blazer and when the truck shifts into second gear it acts kinda sluggish when i try to give it gas. All the other gears seem to work just fine so does anyone kniw what this means? I know some car stuff but nothing like this.
Old 02-06-2019, 07:27 PM
I assume that it has a TH350. It is possible that you have an issue with one of the clutch packs not unlocking properly and dragging in 2nd gear. How does the fluid look?
Does the engine have any vacuum leaks? The TH350 uses engine vacuum to control shift timings and line pressure (I think). If there was a problem with the line to the transmission it could cause problems.
mike90
04-21-2017 10:17 AM
insanefirewall
12-07-2014 07:20 PM
brdshootr
09-30-2011 08:34 PM
75 blazer
08-13-2010 06:36 AM
Redneckgirl
19
12-30-2008 07:05 PM
Quick Reply: Need some help
