Need some info on manual tranny
Ok, I'm not trying to venture into this now, but I would like some info... I did a search, but everything has been for the 2 door version of the truck...
I have a 97 4door 4x4 Jimmy, I would like to convert over to stick. The info I need is would driveshafts, transfer cases, etc work? What I mean is could I use the parts I have in there now mated to a manual? Just checking on info for spline counts, lengths, clearances etc. Fabbing up mounts or what not isn't an issue...
Anyone ever done this before?
The 4dr was never offered with a manual transmission. You may have to have some new driveshafts made up once everything is installed and you know your lengths. If you find that the bell housing to front and rear output dimensions are the same between the manual and automatic transmissions, then you should be able to bolt it in with no troubles. You will then need to install the clutch master cylinder and pedal as well as have your PCM tuned to block out all of the current automatic transmission integration.
blueblzr79
04-05-2012 11:07 PM
LUV2BLAZE
06-14-2010 11:06 PM
midnightmekanik
08-24-2009 09:38 AM
