needing help!
Old Sep 17, 2014 | 11:21 AM
josh.lee13's Avatar
josh.lee13 is on a distinguished road
Default needing help!
needing help with my 95 blazer. its throwing the code for knock sensor bank 1 i replaced it still threw the code. i checked the wire it is fine. and i found a wire for another knock sensor but cant find the sensor it self. also will the po300 code be thrown for a bad tps?
Old Sep 17, 2014 | 07:31 PM
odat's Avatar
usually there is a sensor in the drivers side head inbetween the exhaust outlets in the head - other is usually located in the back of the riders side head
Old Sep 17, 2014 | 08:43 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
A p0300 is exactly that....... A general misfire affecting all cyl.....and given the nature of the fuel systems I would start by doing a fuel pressure test!!!! Then , if that all checks out, ? Go thru the secondary ignition system......very very important that u use delco cap,rotor,& plugs!!!!! As far as wires ac delcos or autolite premium only......if u do a search u can find several threads regarding the p0300 & the proper testing procedure for your fuel system....goodluck, and remember u are in the right place for all the help u will need !!!!
daniel010
Jan 25, 2009 11:10 PM
jhoe414
Sep 29, 2008 08:51 PM
bbsccr01
Feb 23, 2008 01:26 PM
LittleT
Oct 17, 2007 09:45 AM
MsRandi
Jun 26, 2006 06:17 PM
