New distributor timing problems
Old Jan 18, 2015 | 05:38 PM
gtmccormick's Avatar
gtmccormick is on a distinguished road
Default New distributor timing problems
I installed a ready to run dustributor in my blazer with SBC 350 it rotates but won't fire I brough the engine to TDC several times installed the dissy no luck I have the distributor pointing as close as I can get to cylinder one which almost looks like it pointing at cylinder 3… if I move it over the next notch has it sitting at least an inch past cylinder one. I have spark at the coil and spark going down I'm at a loss the plugs are in the write order and don't think its 180 off
Old Jan 18, 2015 | 10:03 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
what year is your blazer?
Old Jan 19, 2015 | 12:27 PM
Default Blazer year
1985 just put a sbc 350 with th350 tranny in it
Old Jan 20, 2015 | 12:39 AM
Default Help
Spent several hours trying to get it to fire no luck is it possible the harmonic balancer is giving bad reading…it you bump the engine it doesn't ever get close to zero. I can crank it by hand set it spin it never comes back to zero. Should I take the water pump cover off check the cam? Im grasping at straws and losing my mind
Old Jan 21, 2015 | 09:58 PM
Turns out it was a fuel problem
Old Jan 21, 2015 | 10:10 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Haha. I went through the same thing when I did my first distributor on my 327. Turned out it was flooding and fouling the plugs. Fun to learn the hard way.
Project96
May 11, 2012 08:32 PM
jimnva
May 3, 2012 05:52 PM
justinh4578
Sep 4, 2011 03:30 PM
dve330
Apr 10, 2011 07:17 PM
Pappa Bear
13
Mar 15, 2011 09:34 PM
