-   -   New distributor timing problems (https://blazerforum.com/forum/engine-transmission-35/new-distributor-timing-problems-88571/)
gtmccormick Jan 18, 2015 05:38 PM
I installed a ready to run dustributor in my blazer with SBC 350 it rotates but won't fire I brough the engine to TDC several times installed the dissy no luck I have the distributor pointing as close as I can get to cylinder one which almost looks like it pointing at cylinder 3… if I move it over the next notch has it sitting at least an inch past cylinder one. I have spark at the coil and spark going down I'm at a loss the plugs are in the write order and don't think its 180 off
canuck blazer Jan 18, 2015 10:03 PM
what year is your blazer?
gtmccormick Jan 19, 2015 12:27 PM
Blazer year
1985 just put a sbc 350 with th350 tranny in it
gtmccormick Jan 20, 2015 12:39 AM
Help
Spent several hours trying to get it to fire no luck is it possible the harmonic balancer is giving bad reading…it you bump the engine it doesn't ever get close to zero. I can crank it by hand set it spin it never comes back to zero. Should I take the water pump cover off check the cam? Im grasping at straws and losing my mind
gtmccormick Jan 21, 2015 09:58 PM
Turns out it was a fuel problem
TZFBird Jan 21, 2015 10:10 PM
Haha. I went through the same thing when I did my first distributor on my 327. Turned out it was flooding and fouling the plugs. Fun to learn the hard way.
