New rod bearings , no holes
Old Nov 30, 2011 | 10:21 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Default New rod bearings , no holes
I was getting ready to install my pistons tonight and I noticed the new rod bearings don't have holes drilled in them like the old ones do . Now is this normal ? The holes need to be there right in order for oil to pass through . I called the manufacter and they said they are the right bearings but I don't see how the oil would get in there .
Old Dec 1, 2011 | 05:07 PM
atvwarrior's Avatar
Well I called summit racing and the new bearings are high performance racing bearings made for more rpms and better lubrication . So problem solved .
Old Dec 1, 2011 | 05:09 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
There is no need for the hole. The oil is suppied through the crankshaft and the bearing rides on a layer of oil between the crankshaft and the bearing. Oil doesn't go between the bearing and the rod.
Old Dec 1, 2011 | 06:15 PM
As jck1961 stated, rod bearings do not have holes in them. Just a plain split bearing. Only the crank main bearings need holes for the oil galleys to feed them & the rods.
Nuikala
Jun 25, 2012 02:08 PM
ceanern
Jun 25, 2012 12:44 PM
chevygonzalez
Oct 31, 2010 08:11 PM
atomicturd
Jan 21, 2010 12:11 PM
blazinrebel
Apr 24, 2008 05:42 PM
