Next project
Old Aug 7, 2013 | 03:52 PM
newguy's Avatar
Default Next project
Transmission temp gauge. Anyone else done this?
Old Aug 7, 2013 | 05:22 PM
chris015's Avatar
its cool. ive never done it. but for what ive found there should be a cap on the driver side of the trans. remove it. put the gauge line there. Should be like 170-215 degrees.
I might be wrong. its just info ive found over the years.
Old Aug 7, 2013 | 05:23 PM
newguy's Avatar
Yep ,been researching it, shouldnt take long
Old Aug 7, 2013 | 05:35 PM
chris015's Avatar
naw. hardest part is finding where to run the line. Id say drill a hole with a uni-bit. and find a rubber bushing to fit it. imma do it on my new blazer some time or another. Il make a tutorial.
Old Aug 7, 2013 | 05:43 PM
newguy's Avatar
Behind the cruise control under the hood is hole that the hood latch cable goes through
Old Aug 7, 2013 | 05:48 PM
chris015's Avatar
ive used that hole for a oil temp gauge and it was almost impossible to get the end through it. Ended up cutting a new hole. Try it though. you will probably have more patience.
Old Aug 14, 2013 | 02:39 PM
newguy's Avatar
So the trans temp gauge is installed, Hole on side of trans is to small (pressure port) so I installed it on the oil to radiator line. While driving it hovers around 140. Stopped and let it idle for 5 minutes or so and it went up to 160. part of the temp line is about 2 inches from the exhaust and I think it picks up some heat from that when not moving
Old Aug 16, 2013 | 10:09 AM
grizzstang's Avatar
grizzstang is on a distinguished road
For a more accurate trans temp the temp sensor should be mounted in the output line heading to the rad. You will get your hottest readings there.
Old Aug 16, 2013 | 12:43 PM
newguy's Avatar
Bingo, that`s where it is
Chevy33
Mar 17, 2012 12:38 AM
chevyblazer9588
Aug 5, 2011 08:44 PM
Biohazed
Mar 24, 2010 05:35 PM
calicojack
Lifting Tech
Mar 8, 2010 06:14 PM
a_tack
Mar 7, 2008 08:06 PM
