No 3rd or 4th gear
Old Dec 18, 2012 | 01:51 AM
pudgedawg007's Avatar
pudgedawg007 is on a distinguished road
Default No 3rd or 4th gear
A while back I was getting on the freeway and went to speed up to merge on, and my transmission felt like it shifted into neutral. I pulled the code and it revealed a transmission slip (don't remember the code). So I bought a used transmission from a place that sells engines and transmission with 80,000 miles or less (supposedly from Japan). So installed the new to me transmission same thing no high gear. pulled it back out exchanged it for another one. Installed it and same thing NO high gear. Now I am thinking that there is something wrong that is not the trans. Someone please help. I need my truck back up and running.
It is a 2000 Silverado 5.3 4x4
Old Aug 16, 2017 | 05:53 AM
Fixitralph's Avatar
Fixitralph is on a distinguished road
Default Did you ever find out the problem?
have you found the problem? My truck is doing the same thing, I have changed the solenoid new valve body. I'm at my wits end don't know what else it could be
Old Aug 16, 2017 | 06:31 AM
newguy's Avatar
3 4 clutch pack is shot. Time for a rebuild
Old Sep 24, 2017 | 08:28 AM
chiggenbotham420's Avatar
chiggenbotham420 is on a distinguished road
Question
2001 blazer transmission 4l60e. Soon as it gets hot it starts slipping. But I can shut the blazer off in N then start it back up then it act like its normal. Please help going nuts on this
greenhornet
Apr 28, 2012 07:28 PM
gomfrddy
Mar 28, 2012 06:27 PM
paul94blazer4x4
Jul 11, 2011 06:01 PM
1blkblazer422
May 3, 2009 07:31 PM
alangri
Apr 4, 2008 07:14 AM
