No compression in #4 Cylinder
Old Apr 30, 2010 | 08:40 AM
jhturbo's Avatar
jhturbo is on a distinguished road
Default No compression in #4 Cylinder
The car was running fine, then it just died. It would not restart, so i had to get it towed. Just to get it running again they had to replace the distributor cap. After that diagnostics were run and found out that i have no compression in the #4 cylinder. What are the causes of this?
Old Apr 30, 2010 | 08:48 AM
Could be a burnt/bent valve, bad piston and/or rings, or a blown head gasket. Any of which requires the removal of the head.
Old Apr 30, 2010 | 10:12 AM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
So you (they) did a compression test and found #4 has no compression ? Or it is just not firing on that cylinder ? Because you said it was running fine before,,,,, Hummmm, All they did was a distributor cap replacement. How are the plug wires, Maybe the #4 plug wire is bad? Sparkplug ? How many miles are on your Blazer and what year is it ?T.J.
DaddysBlazer
Aug 21, 2011 08:19 PM
Jonas
Mar 4, 2011 08:25 AM
bigdaddykane93
Jan 23, 2010 02:10 PM
bigdaddykane93
Nov 16, 2009 10:47 AM
93LT
Jan 16, 2006 09:36 PM
