no crank lots of power can get it after...
no crank lots of power can get it after turning the key off and on like 20 time im thinking starter but wire all look fine grounds looks fine.
i turn key, volts read fine for cranking, but it just clicks 1 time a key turn, it does not keep clicking. any help where to look next?
have you checked voltage at the starter? if voltage looks good, then next thing i would try is to loosen the starter, and hold it in your hand as a friend or someone else tries to crank the motor. if the starter turns, then thats not the issue.
Sounds like a bad alternator to me possible starter problem.
Try a light tap on the side of the starter don’t dent it or anything.
I usually use the wooden end of the hammer and bang on it twice.
If it starts then it’s the starter.
Take the alternator to a small motor shop and have them check it and rewind it cost about 1$ per amp.
I put a 150amp kit in mine.
93 s10 justin
03-05-2010 04:09 PM
90K5Blazer
10-07-2009 10:01 PM
