no reverse
Old Jan 23, 2012 | 03:18 PM
my99blazer's Avatar
my99blazer is on a distinguished road
Unhappy no reverse
without any warnin..... i bought a 99 chevy blazer n great condition (so i thought) a week later on a road trip to texas i pulled n2 a movie parking lot 2 sharp and had 2 stop.,when i went 2 back up i had no reverse & to top it off th trip back th blazer wouldnt shift right & RPMs run high, till this it is a SLOW take off. I have heard different ways and prices to fix it. My question what do i do? ( fluids have been checked )
Last edited by my99blazer; Jan 23, 2012 at 03:26 PM. Reason: left off some details
Old Jan 23, 2012 | 06:02 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Top 30 Common 4L60E Transmission Problems and Repair
Below is a list of common transmission problems with the GM 4L60E Transmission and possible solutions to repair. Although you may have some of these symptoms / problems with your 4L60E Transmission, the repair solution may differ. This list is merely a guide to the possible solutions. For a complete diagnosis on your GM 4L60E Transmission problem, contact us for a Free Diagnostic.
1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the transmission may help (must remove valve body), or adding a high-viscosity additive or other seal restorer product. May also have worn boost valve (can replace in the pan).Hope this helps .
msfan324
Dec 4, 2009 01:40 PM
oshkosh
Oct 11, 2009 01:56 PM
BEENDIGGIN
Feb 15, 2007 11:01 PM
BlazerRJM
Jan 23, 2007 10:32 PM
prnswitch
Feb 16, 2006 03:57 AM
