No spark
Old Mar 9, 2010 | 08:29 AM
acivicone47348's Avatar
acivicone47348 is on a distinguished road
Default No spark
I have an 1995 chevy blazer that i have replaced the crank sensor the cam sensor, the coil and the Ignition control module, I even bought a ECM out of a junk yard and tried it but I still can not get spark out of the coil there is power to the coil and the IGM but no spark all the fuses are good what else is there that could be the problem? Someone please help
Old Mar 9, 2010 | 08:32 AM
You may want to start tracing all of the wires from those components back to the ECM. You probably have damaged wiring somewhere in the loop.
Are there any codes present?
Old Mar 9, 2010 | 09:02 AM
The codes that were present was for the cam sensor and the knock sensor. Would the knock sensor stop spark?
Old Mar 9, 2010 | 09:07 AM
A knock sensor code shouldn't cause there to be no spark.
Old Mar 9, 2010 | 09:34 AM
I also have power to the coil and powere to the ECM could the ignition switch be bad?
Old Mar 10, 2010 | 05:47 PM
ChrisC's Avatar
ChrisC is on a distinguished road
I just had a no spark situation over the past weekend. Turned out the be the chinese module the PreviousOwner installed on my blazer. If I let it sit for a day or two it would crank up and run sh!tty for 5 minutes or so then die, and then it would not start back up at all. Got a actual GM module and runs better than it ever has. Did you use a halfway decent module?
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
thorbergdt
Engine & Internal
Jan 5, 2005 10:02 PM
