No start won't even attempt to fire
So was it the fuel pump relay or was it moisture in the distributor or was it a bad timing belt or was it a bad coil pack - or does it still refuse to start? Not butthurt - but I don't have much time for those who ask for help, yet don't follow it when given. Simple as that.
George
You don't put oil in by pouring it on the engine and hoping it will suck in somewhere! Why start guessing and hoping to hit the actual problem based on what someone else in the Internet says fixed theirs. That my friend is only one-dimensional thinking and I could see you doing it.
With a Blazer no-start - you always start by verifying fuel to injectors. Then move to ignition. Then injector pulses. And so forth. If you don't have a logical plan, then you are just guessing.
At some point because its easy and cheap to do, you could pull a couple of spark plugs and check for the vehicle being flooded. Or just hold the pedal to the floor while cranking with a fully charged battery (max 30 seconds). If it is, check temp sensors with a scanner when cold.
To add to Les' thoughts about diagnostics
https://blazerforum.com/forum/2nd-ge...k-flow-103979/
and my thoughts on no start:
https://blazerforum.com/forum/2nd-ge...rticle-103750/
BTW, my butt does not hurt either.
George
George
Sorry for jumping in here but I was researching and saw the situation and would gladly accept your assistance. I purchased a 2004 ZR2 a week ago. I don't put much on sellers but was told the proverbial little old lady was driving and it just stalled. They guy who I purchased it said he did so to repair it. he put in a fuel pump and new plugs and wires. So not being my first Blazer rodeo I checked the fuel pressure. 58psi proper bleed down. I added new cap and rotor. I also ow a 2004 Jimmy ZR2 so I removed the coil and coil module assembly and it works fine in my jimmy. So now I have run my course and would like to understand the passlock. I might note the alleged little old lady didn't install the pioneer 7 inch and amp which has wires everywhere so I suspect someone might have shorted something. What were you going to say about what is the security light doing? Oh yes, I have a good OBD11 scanner and it shows no codes. Feel free to ask any questions and sorry for my long winded journey to the point.
OK, now we can get started.
If your cranking but not running then you either have a problem with fuel (pressure or injection), spark, timing or air
Since you already tested fuel pressure we will assume that your fuel pump is OK
Next up is spark. While cranking look for 1" of strong blue spark with a steady cadence on at least two ignition wires at the plug ends.
If that OK then its on to injector pulses. You say that you security light is flashing which can be a passlock problem but not always. It can be other things like a class 2 serial communication link failure between modules for instance. If the passlock sensor is defective or changed without a proper relearn, the usual malfunction is it runs for a few seconds after cranking and then dies as the PCM disables the fuel injector pulses. You don't state that behavior or answer all of my questions so we need to check the fuel injector pulse signals during cranking. First up is checking for 12V on the 6 pink power wires going into the fuel injector harness while in the run position.
If that's OK then we need to check for ground side control pulses from the PCM on the other 6 wires in the harness with a noid light or a test light. If we end up here I can guide you if you need help.
Report back.
George
Report back.
George
