No start won't even attempt to fire
Old Feb 15, 2022 | 01:51 PM
  #21
surreybrad's Avatar
surreybrad will become famous soon enough
I'm back and no spark. I checked to make sure the new rotor was on properly and all new wires are in order. So what would you suggest.
Old Feb 15, 2022 | 01:56 PM
  #22
GeorgeLG's Avatar
Pull the lead off of the ignition coil and check for spark there. If not check for 12v on the pink power wires at the coil and the ICM with the ignition in the run position.
George
Old Feb 15, 2022 | 02:09 PM
  #23
surreybrad's Avatar
Already did the pink wire and it's 12 volts. I put the coil and I'm in my other zr2 and they are fine.
Old Feb 15, 2022 | 02:26 PM
  #24
surreybrad's Avatar
I'm currently trying the crank sensor in my running zr2 to eliminate that. I notice it was loose and the retaining bolt hand tight.
Old Feb 15, 2022 | 02:35 PM
  #25
surreybrad's Avatar
Crank sensor works fine.
Old Feb 15, 2022 | 02:36 PM
  #26
GeorgeLG's Avatar
You need to test the two pink power wires (one at ICM and one at coil).
After that its:
Spark out of the coil
The ICM ground
Pulses to the ICM
Pulses to the coil
Crank sensor, its output and wiring
That's enough for now, report back
George
Old Feb 15, 2022 | 02:37 PM
  #27
GeorgeLG's Avatar
The sensor needs to work and the signal needs to get to the PCM so the wiring needs to be checked.
George
Old Feb 15, 2022 | 04:07 PM
  #28
surreybrad's Avatar
When I took the crank sensor off the bolt was hand tight. When I put it back on it seemed to go in further and after tightening it up I decided to try it and away she goes running perfect. My $1000 ZR2 purchase just turned into a $6000 ZR2. As the kid stole the sub from the back when I went to back up my trailer to load it I just had to let him know it was just a loose bolt that made him sell it. Isn't life ironic. Thank you for your time and help.
Old Feb 15, 2022 | 05:41 PM
  #29
GeorgeLG's Avatar
Proper diagnosis makes another happy customer.
George
Kangblazer
Jun 15, 2017 03:40 PM
2000_blazer
Jul 28, 2013 09:16 PM
kp2000
Apr 28, 2011 07:19 AM
danzy555
Sep 12, 2009 02:44 AM
