on nooo throwing a code :(
Old Dec 6, 2010 | 12:21 AM
Zerbla96's Avatar
Zerbla96 is on a distinguished road
Default on nooo throwing a code :(
hey so my CEL came on i took it to autozone and i found out the code its throwing its P0171 "The powertrain control module uses the oxygen sensor to calculate the air to fuel ratio of the engine, the comp recognized a rich or lean condition on one engine bank only. problem cause ( if bank one and two codes set together suspect fuel pressure or MAF sensor oxygen sensor defective, ignition misfire-rapair, fuel injector problem"
my truck starts and runs perfect and i have no loss in power what should i do not really good with engines i just know how to do my basic maintenance should i just replace my MAF or take it to a mechanic ?
Old Dec 6, 2010 | 06:00 AM
P0171 - Fuel Trim System Lean Bank 1
You could clean your MAF and look for vacuum or exhaust leaks.
Old Dec 6, 2010 | 11:44 AM
Zerbla96's Avatar
thanks i hope cleaning it works
Old Dec 6, 2010 | 12:24 PM
Post up in this thread if you have more related questions and we'll help you through it!
Arepok
Jan 28, 2011 12:36 PM
Brian_D
Jun 25, 2010 11:24 PM
demsome
Sep 22, 2009 09:04 AM
abadinalbany
Jun 25, 2009 03:52 PM
schnarr
Aug 25, 2008 11:37 AM
