Not a Blazer but a 4l60 problem just the same
06 Tahoe, I know it's not a Blazer, don't shun me lol
Here's what I know, NO power to pin E of connector. IgnO 10 amp fuse is good, pink wire at plug no power.I found it is circuit 1020. No time to run down the entire circuit and I don't have an electrical diagram.
So my question is this,,,, Can't I just run another fused 12v source wire to pin E of the 4l60 plug ? Shouldn't that give me power back to all my solenoids ?
Is there any adverse effect to this type of remedy ?
Thanks for any and all replies Preciatit !!
It looks like a pretty simple circuit, so I would think that would work. I would make sure to remove the terminal at the plug and use a new one for the "new" circuit to avoid any future issues with feedback through the original circuit.
You might want to wait for somebody who knows more than I do, though.
Hey Tom,thanks for the diagram,it does show part of the circuit but not down to pin E..I will hang out I'm doing some weed eating at the shop so I'll check back every so and so to see if anyone else chimes in..Tks again for the diagram bro !
Hey Brad,tks what about pin N do I need to apply 12v there as well ?
Ok well I have issue still. Ran new circuit and it shifts 1 time then blows 10 am fuse.I moved my circuit to a different spot,same thing.I have these codes po758,po740,po753,po785. I replaced both a nd b solenoids with new GM before I did the new circuit.
Do I have a shorted internal harness ?
