Not starting when hot or cold
Old Feb 17, 2008 | 11:57 PM
NEdeadhead's Avatar
NEdeadhead is an unknown quantity at this point
Default Not starting when hot or cold
I posted earlier with the "not getting fuel . . . " and I guess I worded it wrong. It is not starting when the engine is hot or cold. If the outside temp is around 35 or above it starts first turn of the key, anything below and no luck (although the other day it was 18 degrees and just ona whimI tried it and it started right up. Drove it a while, let it warm up and shut it off, andI was back in the same boat, no starty upy). But if I have driven it for a while and shut it off, it won't start either. It seem to be not getting any gas. There seems to be abundant pressure at the schrader valve, but haven't been able to put a gauge on it yet. The pump is new, filter is new, dist cap and wireset are new. There seems to be sufficient spark. Also when running, it hesitates or stutters from a stop or when revving engine in park, and bogs down bad when accelerating. Could this be the fuel pressure regulator, or perhaps the relay? Fuel pump operates correctly, so that makes me think the relay can be ruled out.
Old Feb 18, 2008 | 06:57 AM
Default RE: Not starting when hot or cold
*Post Closed* - Double Post
Please try to keep things in one place as it makes it easier for those that are trying to help. It reduces duplicate diagnostic steps when everything is in one thread. I have merged your post above into your previous thread. I hope you are not offended by this measure.
Thank you,
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
reeehhh
Sep 20, 2008 10:06 PM
NEdeadhead
Feb 19, 2008 09:53 PM
