-   -   Odd Issue (https://blazerforum.com/forum/engine-transmission-35/odd-issue-27187/)
BlazerLove Feb 3, 2009 03:12 PM
Odd Issue
This one has me kinda stumped. My blazer runs like a champ since I replaced the FPR. However, I have noticed a weird issue while driving. It only happens when I am coasting. I'll have my foot completely off the gas pedal while travelling down a gentle slope and every 3 or 4 seconds its almost like the transmission 'bumps?'. The best way I can describe it is it feels like it disengages for just a split second resulting in a slight 'bump' of deceleration. This only happens when coasting in overdrive.
Any ideas?
corvette535 Feb 3, 2009 03:55 PM
RE: Odd Issue
there seems to be a lot of that right now.... chances are its not the tranny. mines doing that same thing in overdrive under very very light throttle around 2k rpm.. next time it does this look to see if your rpms are jumping around or not...i'm starting with cleaning the egr and o2s then moving to test iginition coil and TPS this weekend to see if that clears it up.
BlazerLove Feb 3, 2009 05:10 PM
RE: Odd Issue
The RPM's do drop by about 500 when this 'disengage' occurs.
When I changed my FPR 3 weeks ago I cleaned the EGR and replaced the O2 sensor. Haven't ever replaced the coil..or TPS.. I will look into them. I didn't think that the CPI had a coil.
BlazerLove Feb 3, 2009 11:04 PM
RE: Odd Issue
Anybody else have any ideas? I'm worried that it may be the tranny.. and usually problems with the tranny only get worse, and that is the scary part-there is no way in hell i can afford a new one. I might as well do a hot and cold transmission fluid check tomorrow.
mofiddle Jun 7, 2010 04:01 PM
I have the same issue did you guys have any luck fixing it yet
00 4x4x4
Denominator Jun 7, 2010 09:31 PM
Same problem here, you describe my problem better then me :)
I do NOT have the drop in RPM, but all the other things..
https://blazerforum.com/forum/engine-transmission-35/added-weight-one-person-jerking-back-44079/
