Oil in antifreeze
Old Apr 18, 2011 | 10:12 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Default Oil in antifreeze
My dad has a 97 S10 with the 4.3. He had a small coolant leak in it and put in a bottle of Bars stop leak a month ago. It didn't really do any good with the leak but he was checking the fluids today and noticed the coolant was quite a bit above normal in the recovery tank. He stuck his finger in it and said it was like engine oil. Then he checked the engine oil and it was about 1 1/2 quarts low. Never used any oil before. No leaks. The engine oil looks clean- no milkshake. Nothing coming out of the exhaust. What could cause this? If it was the headgasket wouldn't it have antifreeze in the oil?
Old Apr 18, 2011 | 11:57 PM
rriddle3's Avatar
Sounds like the oil cooler line inside the radiator has ruptured. Replace the radiator, flush the coolant system well to get rid of the Bars Leak crap.
Old Apr 19, 2011 | 05:58 AM
As Rich has stated, if the truck is equiped with an oil cooler inside the radiator (standard on 4wd's IIRC - located in the driver side radiator tank), the cooler could have ruptured allowing oil to leak into the cooling system. This is really the only way that oil could get there and not allow coolant into the oil. The engine lubrication system is typically running at higher pressure than the cooling system.
Old Apr 19, 2011 | 08:55 AM
95Jimmy's Avatar
Awesome guys thanks. For some reason I completely forgot about the oil cooler in the radiator. Always thinking the worst I guess lol.
Travis West
Dec 23, 2014 07:59 AM
ozziebear
Apr 11, 2011 05:45 PM
sants
Jan 1, 2011 09:48 AM
SWDinehart
Mar 16, 2010 11:31 PM
Spookypaws
Jun 19, 2009 06:34 PM
