Oil cooling lines
Should i get original engine to filter oil cooler lines from the dealership or from the parts store? reason im asking i just replaced the current ones that i got from rockauto when i rebuilt my engine 1 month ago and the line is already leaking from where they crimped the metal to the rubber hose.
Just delete the oil adapter and cooler lines all together and put the filter on the block, eliminate all the leaking, no matter what, they will end up leaking again unless you go to a hydraulic hose shop and get some hydraulic hoses made.
Now How does this work? I like this idea. There are threads for a filter at the block? Still have to get oil to the cooler no?
Im not asking how to fix it i already know how to fix it im asking if any one had better luck with with the dealership part then the local parts store that sells dorman brand
All ya need to do is remove the remote adapter, the adapter on the block, clean up the gasket on the block, then install this part onto the block using a allen wrench and some blue thread lock on the threads gm # 14081300
and then get this oil filter WIX 51040 which will stay clear of the front shaft ect. and you are good to go. I am doing this to my first gen. I already have the gm # 14081300 for it, I just need to find time to do it.
How is this going to work with a 4x4? There's no way for an oil filter to fit between the front differential and block. It's already darn near impossible to wiggle out the adapter block, and it is substantially smaller than an oil filter.
