Oil Gage
Old Dec 13, 2007 | 03:29 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default Oil Gage
I just recently got my engine replaced in my 2000 trail blazer edition and for some reason whenever i hit the gas my oil pressure gage goes up almost to the 3/4 mark but no higher. What might the problem be with this, or is it??
Old Dec 13, 2007 | 03:30 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default RE: Oil Gage
oil pump goin bad, i had the same thing happen to mine, oil pump goes, bottom end of the motor goes. watch yourself. if you start to hear a tick. DO NOT DRIVE IT.
Old Dec 13, 2007 | 04:02 PM
I doubt the pump is going bad in this case. When at higher RPM, it is normal for the pressure to rise. The 3/4 mark should be roughly 60psi which is high, but not excessive. My old Bravada would get up that high on a cold start and would drop to around 40psi under acceleration once everything was up to operating temperature.
What pressure is it running at idle?
Old Dec 14, 2007 | 07:23 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
swartlkk is right one this one. My blazer on cold startup usually has about 60 psi when it is idling about 35 psi or so and then when doing driving it stays about 42-43 psi.
So driving it or revving the motor will cause the oil pressure to go up. Especially if it is right after a cold start-up in which case I suggest you stop doing it. Give the oil some time to circulate before putting any strain on the motor.
Old Dec 14, 2007 | 10:48 AM
cliro's Avatar
cliro is an unknown quantity at this point
mine does this too, it's a 2004 with 75000 km on it. think it's fairly normal.
Old Dec 15, 2007 | 12:29 PM
RCarp48's Avatar
ya it probably doesnt even get as high as the 3/4 but it never did it b4 when my old engine went so idk, but it sounds just like all of yours so i guess im ok hopefully
janddcunningham
May 25, 2011 11:14 AM
Rryder
Jun 24, 2009 03:11 PM
Danketch71
Mar 13, 2008 09:18 PM
blazin true
Dec 12, 2007 06:34 PM
NCStone
Jul 15, 2006 02:52 AM
