Oil Pressure
Hello, I have a 2000 4x4 4.3l. When I first start the blazer, my oil pressure gauge reads about 60 psi. Once the oil finally warms up it will drop down to 40 psi. However when the blazer is in idle, it will drop down to 20 psi but will jump back up to 40 once I step on the gas. Bad oil switch maybe? Any insight is greatly appreciated.
Others should give their thoughts, but I think this is not out of the ordinary for the 4.3L and matches my experience.
my 2001 jimmy does about the same thing,i really dont like it because the last two i had (2000 blazeer and the 98 jimmy ) were both higher...but i guess not to worry..?
| All times are GMT -5. The time now is 11:21 PM. |
