Oil Pressure ??
Old Jul 26, 2010 | 10:33 PM
Douglas W. York's Avatar
Douglas W. York is on a distinguished road
Default Oil Pressure ??
What is the normal oil pressure for 99V-6 Chevy Blazer when idling, driving, and stopping?
Last edited by swartlkk; Jul 27, 2010 at 06:04 AM. Reason: Moved this off topic reply to a new thread of its own.
Old Jul 27, 2010 | 12:12 AM
fondo's Avatar
fondo has a little shameless behavior in the past
WTF? Try using the search function...buddy! JEEZ
Last edited by swartlkk; Jul 27, 2010 at 06:03 AM. Reason: Copied from other thread
Old Jul 27, 2010 | 02:27 PM
I tried!!! Duh!!! Evidently you do not knoe the answer.
Old Jul 27, 2010 | 03:06 PM
rriddle3's Avatar
There is no spec as to what the pressure 'should be', but normally you will see ~35-45psi at idle and ~50-60psi while driving. Old rule of thumb, as long as you have 10psi per 1k RPM, you're safe. I believe GM says the engine is safe down to 8psi at idle.
Old Jul 27, 2010 | 03:23 PM
fondo's Avatar
You posted your question as a reply to "my" thread. Please don't hijack someone else's thread. If you go to the search function you'll find at the bottom of the drop down menu "advanced search". Click on that and it will link to another page that allows you to narrow your search parameters. Thanks swartllk for moving this post into its own thread.
IIRC you should be registering somewhere around 20-25psi @idle,35-40 psi cruising speed, 55-60 psi when accelerating. It is best to hook up a master gauge when trying to determine actual oil pressure. The dash gauge isn't always a sound way for monitoring oil pressure.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
