oil pressure advice
Old Dec 7, 2010 | 11:22 PM
appliancguy's Avatar
appliancguy is on a distinguished road
Default oil pressure advice
So after dumping a bunch of money into a 95 blazer it was running great.
Today the oil pressure dropped to 0. Turned off and let cool off. Is full of oil. Started cold 50 psi, let it run 10 minutes and it holds so I head home.
About 5 miles the oil pressure is 20 at 2000 rpm. Get it home and oil pres is now 10 at idle and lifter or bearing tap. give it a little gas and oil goes up and knock stops, then back to 0? Figure I'll drain the oil tomorro and look for metal shavings?????????
bryanmine
May 19, 2011 11:27 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
