Oil pressure drops on idle
Old Jan 7, 2018 | 06:31 PM
Default Oil pressure drops on idle
Not sure about this one, but the blazer loses oil pressure when I stop at lights lately. It goes back up if I rev it, but not to sure what' the cause. Oil levels are good just the pressure issue...
any ideas? Would like to solve before any major issue begins.
Old Jan 7, 2018 | 09:19 PM
richphotos's Avatar
When you say drops at idle. like, to 0? It is natural for the oil pressure to drop at idle and raise when you are accelerating.
Old Jan 7, 2018 | 10:49 PM
What values do you read for the pressure when at idle, accelerating, cruising?
Any other issues going on with the engine?
The pressure sender can go wrong but if the value when running is where it should be perhaps the pump is worn out?
Old Jan 8, 2018 | 01:30 AM
newguy's Avatar
oil pressure higher when cold, around 60. Once warm 40 at highway and around 20 at idle is normal
Old Jan 8, 2018 | 06:24 AM
Snap-Off's Avatar
Snap-Off is on a distinguished road
I'd start with an oil and filter change..Maybe you have a crud blockage in the filter...Just keep the old filter so you can cut it open and have a look to see whats in there.
If the same thing is happening, change the oil pressure sending unit as it may be on t's way out...
If the issue persists, then I'd pop and actual oil pressure gauge on it and see what it says.
Old Jan 8, 2018 | 06:30 AM
Usually when driving my needle will stay right in the middle(275) and idling is just follow it. But it' dropping right down to zero at stop lights.
thanks for the ideas, I will check them out and keep an update on the issue
Old Jan 8, 2018 | 07:37 AM
LesMyer's Avatar
FYI 20 psi = 140 kPa. First change oil and fillter with 5w30. If problem persists either put a real gauge on it or change the sending unit and compare.
Old Jan 8, 2018 | 08:17 AM
Snap-Off's Avatar
One thing I forgot to add...When you do change that filter and open it up, if you see any metal shrapnel, stop right there.. If you don't see any metal , then carry on...
Old Jan 9, 2018 | 02:26 AM
newguy's Avatar
If there was a blockage the pressure would be high
Old Jan 9, 2018 | 06:42 AM
Snap-Off's Avatar
Unless the blockage was oil pump shrapnel caught n the filter...
